biesa
6 December 2018 21:25
#42
just checked. i cant turn it on, i only can disable ssh pass
anyhow - i had to edit my kown hosts on my macbook.
then it worked with ssh but using libreelec as pass!
after typing via shh:
echo “meson-ir * mecool” > /storage/.config/rc_maps.cfg
and reboot - nothing happend. my remote now is not working with any button.
before typing this at least OK was working
biesa
6 December 2018 21:31
#43
before auto update i used this file: M8SPro_
hardware is
M8S PRO+ S905X 2GB-RAM & 16GB Flash
Os is on a Samsung 32GB microSD
but when booting without a sd, splash screens shows mecool.
thats why i used the mecool echo cmd.
try a fresh install to a different usb
biesa
6 December 2018 21:33
#45
oh man really??
smartphone app remote is working
but the external IR not. do i realy need to do this again??
Libreelec, used to have ssh off by default, coreelec has ssh on by default
Well unless you can enable ssh somehow,
A fresh install of coreelec might not be a bad idea
biesa
6 December 2018 21:51
#47
na dont get me wrong.
i had some problems connecten via ssh with my mac.
but i solved the problems on my mac and i could connect now, but using libreelec as pass
but login on by ssh and typing echo “meson-ir * mecool” > /storage/.config/rc_maps.cfg
and reboot does not help. IR doesnt work.
was this cmd correct?
hardware is
worked for me.
But to be on the safe side, just do a fresh install to a different sd/usb, I don’t know which device tree you need for your device, so check that first, by searching the forum, there is a link about device trees somewhere
CI6N0Z
6 December 2018 22:17
#49
@biesa , I’ve 3x of the same box as you have. This is the fastest way to setup everything correct in under 5 minutes:
Download CoreELEC 8.95.6 and unzip
Connect your Micro SD card to your Mac
Write the img-file to your Micro SD card doing the following:
diskutil list
diskutil unmountdisk /dev/disk2 # If your SD card is disk2
sudo dd if=X.img of=/dev/rdisk2 bs=1m # If your SD card is disk 2. Change X with the filename.
Copy gxl_p212_2g.dtb from the device tree folder to where the other dtb.img file is and overwrite it by renaming it to dtb.img
SSH into your box with coreelec as user and password
Run the following to active the remote
Now everything should work just fine
biesa1
7 December 2018 15:08
#50
Did i.
new sd card with the latest img.
ssh via coreelec as pass worked:
Connection to 192.168.0.49 closed.
ssh 192.168.0.49 -l root
root@192.168.0.49 ’s password:
CoreELEC
CoreELEC (official): 8.95.6 (S905.arm)
CoreELEC:~ # echo “meson-ir * mecool” > /storage/.config/rc_maps.cfg
CoreELEC:~ # reboot
CoreELEC:~ # Connection to 192.168.0.49 closed by remote host.
after reboot. remote is not working!
PS: login was root and pass was coreelec -
login & pass: coreelec does not work to login btw!
CI6N0Z
7 December 2018 16:57
#51
Well, that’s strange as I tested this yesterday and everything were just fine…
I’m sure the devs will look into this, especially if there are several people with a Mecool box where the remote is not responding. However, I mapped Mecool M8S PRO+ remote in July which you can try out in the meantime.
Here is the remote config for MECOOL M8S PRO+ which I just created as I had problems with my TV-remote powering off the device when pressing specific keys like KEY_DOWN and the default remote scheme in CoreELEC 8.9.5.
rc_maps.cfg (774 Bytes)
M8SPro+ (474 Bytes)
biesa1
7 December 2018 17:32
#52
so how to fix it with those files?
can you guide me please?
can you tell me what to do by using ssh?
i am a bloody beginner
CI6N0Z
7 December 2018 18:59
#53
ssh into your box and run the following three commands separately. Hopefully it will work and the files will be loaded automatically after rebooting the device. If not, take a look in the Guides or Remote Controllers forum.
wget https://discourse.coreelec.org/uploads/default/original/1X/e143f4a2ae906e5770000587d00b6dbb6ad1175d.cfg -P /storage/.config/
wget https://discourse.coreelec.org/uploads/default/original/1X/1e04bd6a4b522f96d1fee8e857186f453af617f7 -P /storage/.config/rc_keymaps/
reboot
biesa1
7 December 2018 19:48
#54
hmm not working after reboot.
CoreELEC
LibreELEC1:~ # wget https://discourse.coreelec.org/uploads/default/original/1X/e
Connecting to … (116.203.27.52:443)
e143f4a2ae906e577000 100% || 774 0:00:00 ETA
LibreELEC1:~ # wget https://discourse.coreelec.org/uploads/default/original/1X/1
1e04bd6a4b522f96d1fe 100% | | 474 0:00:00 ETA
LibreELEC1:~ # reboot
LibreELEC1:~ # Connection to 192.168.0.49 closed by remote host.
Try to make it from scratch
IR remote controls can be configured in 1 of 2 ways in CoreELEC, both are detailed in this guide below.
meson-ir
meson-ir allows you to use almost any IR remote controller to control your device.
CoreELEC uses meson-ir by default and our builds come with a limited selection of IR remote configurations for devices built in.
If your remote does not work then you will need to follow the below instructions to create a config and get it working.
Firstly you must SSH into your device and then Kod…
And after check that is different in your configuration. May be you need different config
biesa1
7 December 2018 20:20
#56
isnt there an easy way to use my very common box with my ir remote?
why is there such a problem.
one previous version all worked.
will it help to install 8.95.5 and disable auto update?
You can. But in case of future update you will have the same issue.
This procedure is quite simple. You need just follow it.
Also you can upload your ir-remote picture, may be somebody can recognize it and help with right config
Also did you try A95X or minix_neo config?
biesa1
7 December 2018 20:56
#58
you mean, typing all 3 commans via ssh?
echo “meson-ir * a95x” > /storage/.config/rc_maps.cfg echo “meson-ir * mecool” > /storage/.config/rc_maps.cfg echo “meson-ir * minix_neo” > /storage/.config/rc_maps.cfg
biesa1
7 December 2018 21:49
#59
also wondering, that the new sd card with the *.6 img and after the ssh cmd which I tried today, is not working.
this has to be working 100% or am i wrong?
DId you copy and rename the dtb? I have a feeling you either didn’t or you are using an incompatible one as that is the only thing that would cause the issue your having.
Only one of them and reboot. Each command - different config, you have to use only one of them
