Just looking for a little heads up on any pitfalls I may run into.
Presumably, when CE19 connects to the MySQL for the first time, it will try to upgrade the tables as with previous versions?
Is a direct, in place, upgrade working or should I install 19 from Scratch and manually setup all of my add-ins etc?
If not, would copying out the /storage folder from 9.2.7 and dropping it over the top of 19 be OK, or should I just setup the add-ins 100% new and just re-use my advancedsettings/mediasources/sources etc XML files?
