The paste service should be working now. Please try again.
Alright, here it is:
http://ix.io/2nTN
From here for 0bda/5411 https://usb-ids.gowdy.us/read/UD/0bda/5411
I see that inside is RTS5411 4-Port USB 3.0 Hub
datasheet https://datasheetspdf.com/pdf-file/1146777/Realtek/RTS5411/1
Thank you.
Maybe that can help others looking for a hub as well.
I just ordered this hub because it supports Per-port power switching. Hope it will work like I need.
Could you elaborate?
Do you mean that for instance only the one HDD wakes up that is actually needed, not all of them?
There is a project uhubctl - USB hub per-port power control: https://github.com/mvp/uhubctl
uhubctl
is utility to control USB power per-port on smart USB hubs. Smart hub is defined as one that implements per-port power switching.
You can programmably enable or disable power individually on USB sockets. It looks like the device is physically removed.
Got the hub today and of course power switching function doesn’t work But at least hub itself works
And I was waiting 2 weeks for it.
I think chip inside suports the function but some hw is missing around (like few transistors).
