The drives work perfectly when connected to the box directly.
However, as soon as the USB Hub is between box and (any) HDD, the drive does not show up in CE.
Is there any way I can make it work? Adding a driver or something?
If not, can you recommend an alternative, working 4 port USB 3.0 Hub that is not too expensive?
I can still return the TP-Link Hub.
Oh sorry, I should have mentioned that right awayâŚ
Both HDDs are 3,5", externally powered.
So I thought the USB Hub would not have to be active?
Also, both HDDs spin up when connected to Hub/Box and also go to sleep after 15min as they should.
But the USB LEDs on the Hub donât light up and the HDDs donât show up in CE.
Itâs the same when only one HDD is connected.
Accordingly, I believe the power is not an issue, or can it still be?
If the HDDs are self-powered, a power issue is very unlikely. Also passive hub is sufficient in that usecase.
Is the behaviour the same on all USB ports of the box?
Have you tried nightly?
Not yet, I will try to prepare another SD with the latest nightly today.
Is there a way to get feedback from one of the devs if a driver for this VIA chipset in the Hub is even integrated? Where is the best area to ask for something like that?
The manufacturer claims the following:
âDoes not require drivers for Windows 10/ 8.1 / 8 / 7 / Vista / XP or Mac OS X and Linux systems.â
However, I guess our CE Linux is stripped to the necessary parts only, correct?
The hub works perfectly on a Windows 10 computer.
Both HDDs connected, the status LEDs on the hub light up and the drives appear in Explorer right away.
What do you mean by âand later drivers tooâ?
What kind of drivers, where do I get them and how do I add them to CE?
Yes, I see that.
Obviously, the cable is not badâŚ
Also, it is not even detected as a USB 3.0 device
May 26 12:39:19 CoreELEC kernel: usb 1-2: new high-speed USB device number 2 using xhci-hcd
May 26 12:39:19 CoreELEC kernel: usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
May 26 12:39:19 CoreELEC kernel: usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 26 12:39:19 CoreELEC kernel: usb 1-2: Product: 4-Port USB 2.0 Hub
May 26 12:39:19 CoreELEC kernel: usb 1-2: Manufacturer: Generic
May 26 12:39:19 CoreELEC kernel: hub 1-2:1.0: USB hub found
May 26 12:39:19 CoreELEC kernel: hub 1-2:1.0: 4 ports detected
I copied something just for testing in Windows from one of the drives to the internal SSD.
Reading at 170 MByte/s is hardly USB 2.0 speed.
I donât see anything to get it working. I saw some workaround to disable usb and then enabling it back but for this it needs to identify where this hub is connected. And it is hard to explain
The UNITEK hub works perfectly!
I still donât know which Realtek chip exactly is in it, but it surely does the trick.
Both HDDs were detected right away.
Speed is great, 85-110Mbyte/s writing, 65-105 Mbyte/s reading via LAN.
Both HDDs go to sleep after 15min as they should.
If anyone is looking into a cheap hub for their box, this one is definitely worth a recommendation.
It also has a Micro-USB port to supply more power for anyone using 2,5" drives.
It looks like the paste service is down at the moment:
canât get debug descriptor: Resource temporarily unavailable curl: (60) SSL: no alternative certificate subject name matches target host name âpaste.coreelec.orgâ
I guess that command might tell us which Realtek chip it is?
