Hello guys, do you know if there is a limitation connecting external USB drive? I have a pen drive (2TB) that I can use without any problem on the PC but the box can’t detect. I have only one NTFS partition on the pen drive.
Many thanks for the answers!
Which box? Many boxes can use up to 1TB USB drives
GooBang Doo XB-II (Amlogic S905) with CE 8.95.5
No Problems ever, have a 11TB HDD4bay, 16GB SD Card and a 32GB USB 3.0 Stick, on my Bqeel M9Cmax 905X/2GB Box.
Gr33tz
I tried to change the usb slot and on the other one it works fine
