I bought the tt-connect s2-4600 and install the corelec 9.2 with dvb tbs drivers in a odroid N2. install tvheadend and works well with free channels. when I use oscam as emulator and I will open encoded channels does not work. oscam opens the right channel but it seems in corelec not opening a player. does not advance. seems to be missing any configuration. I already installed the cas. the oscam tvheadend connection doesn’t seem to happen.
Can someone help me if it is possible.
This device with firmware before 2017 works well with another DVB driver.
Check Live Log on oscam to find out where the problem is
