USB TV Tuner not recognized at startup
I have a weird problem with my Mygica T230c dvb-t2 tuner.
It’s not working at startup when first turn on the device (cold boot). It does work if I unplug/replug or if I reboot.
It’s connected to usb 3 port of my mecool km9 (s905x2) running Coreelec.
CoreELEC:~ lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 003: ID 0572:c68a Conexant Systems (Rockwell), Inc. EyeTV Stick Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 002 Device 002: ID 325d:6410 USB DISK 3.0
DVB addons installed?
I installed TVheadend server using Kodi and it’s working (unpess I cold-boot). Is there a separate dvb addon?
Read forum.
You need to try like DVB drivers for TBS addon from CE repo.
