Hy please help.
I started it the to rewrite 8.2.3.1 version. (android_win_tools) and I would like to make it so,that the useragent what it sends onto my server let him be unique with what down I have to limit the devices unfortunately. I would like to ask help in this. Thank you.
My box x96s905x Kodi 17.6
possibly the simple itpv plugin let me try to rewrite it?
Yes, pvr iptvsimple does support changing User-Agent: In m3u8 playlist add |User-Agent=“some string” to the end of each url. Or set string in addon itself.
But please, write more clear because posts above doesn’t have much sense.
Geeb, I have to say you are making very confused posts. What are you trying to accomplish? First you are writing about user-agent string, now you like to mount python library over which you did completely wrong way. Correct way is like this (and only if really need such hacks!).
mount -o bind /storage/downloads/urllib2.pyo /usr/lib/python2.7/urllib2.pyo
