Verifying best way to move from CE-NG to CE-NO?
Hi all, I’m looking to migrate from NG to NO on an Ugoos AM6B+ with coreelec currently running from emmc. I found this guide, which seems to say it’s as simple as SSHing in and putting the latest NO nightly in /storage/.update (and rebooting)? Was hoping to verify this is indeed the best way to upgrade, or whether it’s better to do some sort of completely fresh install, especially since it’s running on emmc?
Thank you for any verification you can share!
You are changing kernel versions and going from Omega to Piers
It is always best to do clean install
IMO
Use CoreELEC tool ceemmc-x and remove 4.9 from internal.
Thank you for the response, will follow your recommendation!
