Hello guys!
I switched my old FHD TV to a LG 4k and was very pleased with the picture.
However when watching some videos, they freeze for a few seconds throughout the movie and the audio continues normally.
I did not make any configuration changes (only resolution to 3840x2160p 60).
Does anyone know how to solve?
the videos infos exemple
1080p
https://justpaste.it/4q04e
On old tv worked without problems
4k HDR
https://justpaste.it/7ii9w
This happens in any video.
I use hdmi cable 2.0 and the problematic CEC works well!
and sorry my english!
“NAS” is HDD USB 2.0, and never had this problem
i use the last oficial version, CE 9.2.1…my n2 is 4gb version
videos work normally via PC (samba LAN => PC => TV)
Have you tried changing the cache settings?
https://kodi.wiki/view/HOW-TO:Modify_the_video_cache
Create a file in userdata, name it advancedsettings.xml
Copy and paste say Example 4 in it. Save and reboot the device.
I will try and then return!
thanks
I change the cache and…Don’t work!
freezes in exactly the same parts
What program are you using to all this data of the video being played? Is this a program installed on CoreELEC or is this something you’re running from a computer?
It´s a program running on a personal computer
Mediainfo
Yes, I have that program but I’m not getting all those details. Guess I have to go learn how to use it better…
Got it… changing the views now shows me all this info. Thanks.
