I’ve just installed CE 21 stable to SD card and everything works fine except if I turn the device off (and the TV and AVR also because of CEC) and then back again I get no picture but the menu sounds. Only solution for now is a hard reset AKA pulling the power cable.
Update :
If I connect the Box directly to the TV and not via AVR then I get picture.
Sadly this way I won’t get lossless audio as my AVR is old Yamaha V379 and doesn’t support eARC so I need to connect it to the box first.
Any idea how to fix without hard reset ?
Thanks!
