Wake on LAN / WOL on LePotato
Hi there,
I’m trying to use Wake on LAN on my LePotato.
ethtool eth0 says:
Supports Wake-on: ug
Wake-on: d
In the /flash/config.ini there is a line:
#WOL setting for LePotato
wol=1
By default the line is commented out. Activating it (with remount of course) and enabling it does not change anything in the ethtool output.
Is it possible to get WOL working with LePotato or is the comment in the config.ini misleading?
Thanks a lot for your help!
