My Nokia 8010 does not shutdown, sleep or wake up using the remote. I think I had read somewhere that this is a limitation of using bluetooth? So I always have to turn the power on and off.
If I were to buy a box that uses IR instead, would the shutdown and wake from remote work?
Yes.
At least for power up. Power down you can assign any button you like from a running system.
I use N2(+) that has an ir receiver coupled with an rf remote with an ir power button for this task specifically. Works fine.
