Hi all,
CE 9.2.0, Odroid N2.
Noticed the following in dmesg a couple of times, is it something to be concerned about?
WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
22be8233b34f4f468934c5fefcbe6151766fb8f2 media: videodev2.h: change V4L2_PIX_FMT_BGRA444 define: fourcc was already in use
6bda7073f335db261345d403123d9a8c0bc1e36b media: v4l2-subdev: fix regression in check_pad()
f81cbfc4f82a75ca0a2dc181a9c93b88f0e6509d media: allegro: use new v4l2_m2m_ioctl_try_encoder_cmd funcs
TIA
Greg
