Hello.
I have here some wetek play 2 devices that are running LibreElec 8.
My main goal is to make them capable to read Dolby Vision MKV’s.
Is that possible with coreelec 9.2.8 ?
And if yes… what would be the file i should use?
Thank you very much.
Did you even check if this device supports DV? I assume not because it doesn’t.
Which means your question is useless.
