Hello!
glad if someone can help me.
I updated to 9.02 on wetek play 2 and after updating my iR remote doesn’t work.
Anyone else?
SSH to your device and type remoteinfo
and paste the link, thanks.
hello. here is the link:
http://ix.io/1J8l
remove your remote.conf and reboot
That worked!
hello.i have the same problem.can you help me?
I can’t see anything wrong with your system, are you able to do a fresh install on different media to see if you still have the issue?
this is a backup from my mecool k3 pro system that i installed on my wetek play 2.a fresh install has no problem with the remote.but i have too many addons and settings that i need to transfer over so a fresh install is not good for me.isnt there any way i can activate the remote with this setup?
Did you type remoteinfo
before or after restoring your backup because from that log everything looks like it should be okay.
after restoring.
I think you have restored the mecool remote config and this needs removing but your log is not showing me anything.
Try this and then reboot.
echo "meson-ir * wetek_play_2" > /storage/.config/rc_maps.cfg
Not trying to hijack the thread, but have a similar issue. I haven’t put any new configs or anythings. But i cannot get these to work.
My home button doesn’t do anything and some of the other buttons just show:
2019-08-11 19:52:03.339 T:4012893040 DEBUG: LIRC: - NEW 66 0 KEY_HOME devinput (KEY_HOME)
2019-08-11 19:52:03.349 T:4090314768 DEBUG: HandleKey: 0 (0x00, obc255) pressed, action is
Same thing happens on start , text and keyconfig buttons
Try removing /storage/.kodi/userdata/Lircmap.xml and reboot
I have added that because I was having issues with the remote, I followed a thread over on libre where someone said that they added lircmap.xml which let them map it. I will remove it and it will go back to square one, the issue remains.
It has to be a configuration issue because those keys definitely work.
what can i do to completely reset all things related to remote without wiping the system clean
