Wetek Play 2 remote on ODROID N2 [Guide]
Hi everyone,
My WP2 is broken. I bought a used n2 yesterday. And I wanted to use devices of wp2. I started with the remote control device.
I copied my config files from Wetek as they are.
/storage/.config/rc_maps.cfg
meson-ir        *     wetekplay2
/storage/.config/rc_keymaps/wetekplay2
# table wetekplay2, type: NEC
0x5e5f02 KEY_POWER
0x5e5f46 KEY_HOME
0x5e5f10 KEY_MUTE
0x5e5f22 KEY_1
0x5e5f23 KEY_2
0x5e5f24 KEY_3
0x5e5f25 KEY_4
0x5e5f26 KEY_5
0x5e5f27 KEY_6
0x5e5f28 KEY_7
0x5e5f29 KEY_8
0x5e5f30 KEY_9
0x5e5f71 KEY_ESC
0x5e5f21 KEY_0
0x5e5f72 KEY_CAPSLOCK
0x5e5f03 KEY_LANGUAGE
0x5e5f48 KEY_MENU
0x5e5f61 KEY_BACKSPACE
0x5e5f83 KEY_EPG
0x5e5f84 KEY_COMPOSE
0x5e5f77 KEY_INFO
0x5e5f50 KEY_UP
0x5e5f4b KEY_DOWN
0x5e5f4c KEY_LEFT
0x5e5f4d KEY_RIGHT
0x5e5f47 KEY_ENTER
0x5e5f44 KEY_VOLUMEUP
0x5e5f43 KEY_VOLUMEDOWN
0x5e5f41 KEY_PAGEUP
0x5e5f42 KEY_PAGEDOWN
0x5e5f4f KEY_CONTEXT_MENU
0x5e5f82 KEY_TEXT
0x5e5f73 KEY_RED
0x5e5f74 KEY_GREEN
0x5e5f75 KEY_YELLOW
0x5e5f76 KEY_BLUE
0x5e5f67 KEY_PREVIOUSSONG
0x5e5f79 KEY_REWIND
0x5e5f80 KEY_FASTFORWARD
0x5e5f81 KEY_NEXTSONG
0x5e5f04 KEY_RECORD
0x5e5f2c KEY_PLAYPAUSE
0x5e5f2b KEY_STOP
IR Wake UP code is 0xfd025f5e
Save and reboot. It’s that easy.
Thanks for sharing. I plan on getting rid of our WP2 in the bedroom and now I don‘t need to look for a new remote!
