Hi, I need a USB WLAN Stick with a larger antenna.
Which one runs fine with CoreElec on a Wetek Play 2?
Thank you
Thank you
This one works well on my N2 with CoreElec and Android
Product Description
What do you think about this one
https://www.amazon.de/gp/product/B07R3VJHP8/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Although it may have best specs the usefulness depends on Linux driver availability.
Since there are numerous variants of similarly same chips, not all variants will (yet) work on CE.
So, before you buy any, first find out what chip is used and if it works on CE.
There is already a thread for this discussion.
