Hello!
Box: Beeling GT1 Mini 4GB
CE version: 9.2.8
So, the title of this Topic I guess says it all. After every reboot of CE the system just won’t connect automatically to the Wi-Fi, that was set up previously. So I must manully recconnect to it after every new startup of the system (in the CoreElec->Connections menu). The Wi-Fi is working fine otherwise, after I have reconnected. And it’s not that if it has “forgotten” the password to my Wi-Fi network, it just somehow doesn’t wnat to auto connect to it…
What could possibly cause this probelm and is there a “trick” to resolve it?
Thanks for any helpful reply!
Yes, it has S905X2 SoC. I thought there will be some other “workaround” to solve this, rather than installing the newest CE version (and so wiping entirely the current), could you not suggest something else to try out? And if I really have to install the new CE version, must it be surely the 21 Nightly, the 21.0 Stable won’t be enough?
Through Network
Linux machine
Windows
Make a copy of addons folder and save to desktop/known directory
Ssh connect to box
Now use ceemmc -x CoreELEC Tool
Use option make copy of installed
Save on micro sd/usb thumg drive
Now option in tool remove installed
It is best to now confirm Android Base is working all functions.
New install nightly copy over addons folder contents/or replace
After reboot addons will migrate.
Use nightly because been so long since update maybe stable has not added support for wifi/bluetooth
