I’ve noticed that the TV Shows and Movie Widgets are not updating when new items have been added. eg: This morning I added the TV Series Maid and it did not appear in the Widget:
However it is in the Category Recently added:
Any ideas why the update is not happening in the Widget?
2021-10-08 09:33:10.132 T:4952 INFO <general>: Starting Kodi (19.2 (19.2.0) Git:2ffa0020aede2746711d3dd7611e660828dc26d3). Platform: Linux ARM 32-bit
2021-10-08 09:33:10.132 T:4952 INFO <general>: Using Release Kodi x32
2021-10-08 09:33:10.132 T:4952 INFO <general>: Kodi compiled 2021-10-06 by GCC 10.3.0 for Linux ARM 32-bit version 4.9.113 (264561)
2021-10-08 09:33:10.132 T:4952 INFO <general>: Running on Hardkernel ODROID-N2 with CoreELEC (official): 19.2-Matrix, kernel: Linux
Just installed Win10 on a VM and installed Kodi 19.2:
Both CE and windows Kodi are doing the same thing. I did notice that if the widget was empty it would not update when a new item is added (Movie or TV Show) until Kodi was restarted. This happened on CE and Windows.
If something is already in the widget and a new item (Movie or TV Show) is added both updated as they should.
If this happen on Windows to please open a issue at XBMC GitHub including the log of the Windows version as you will get no support with the CE version at XBMC GitHub, thank you.
