First time CoreElec user, just wondering what user friendly skins people are using with widget support for Android? I’m using (edited) video addon and tried the node editor but it just seems clunky and incredibly complicated.
You referred to a repository banned by Kodi. You can discuss your skin changes without the mention of the banned add-on or the thread has to be closed.
Hello. I want to create some category based on the value of MediaTag : 4K and Dolby Vision.
Do you know a skin (not banned) that allow to filter on these value?
Thanks for your help.
No I’m not sure. Your best bet would be to log in to Trakt website and look through the lists on there. Find a few 4K and Dolby Vision lists and click on like so that it registers that you have liked that list. After that (at least in the Arctic horizon skin I use) you can add widgets for Trakt “liked lists”, and then you will have them in your home menu. I do this with different categories so that I have several movie categories, several TV categories and several documentary categories.
