I have installed in my Mecool KIII PRO the DTB (gxm_q200_k3_pro), apparently after some adjustments Kodi works fine. Now lets activate Wifi and configured, all Ok. Then I have rebooted and check internet, nothing no internet. Validate all configurations again and all well configured. What can be wrong here?
You give almost no information about the circumstances of your problem.
Wi-Fi connections sometimes present problems due to interference from neighboring WiFis that use the same radio channels. Check this. As my neighbors change the radio channels often, my router is set to reboot every day and find the best available radio channels in the 2.4 and 5GHz bands. This works for me.
Also check the IP assignment for CoreELEC. If you have a manual IP, check that it is outside the range of dynamic IP allocation on the router.
Finally, sometimes a simple router reboot solves the problems.
Many thanks from your input I will do that, then give you a feedback.
Thanks.
