I am new to coreelec and would like to try it first. I have a Wetek Play 2 with Libreelec 8.2.5 installed in NAND. Is there a way to install coreelec on an SD card and choose between both when booting? Unfortunately I have to do this because I have to check if everything works so far because of the very important WAF. :-/
i have a tx3 pro that have CE on internal and LE on sd card. no special instructions, just install normally. you have an option to reboot via internal or sd.
The official LE 8.2.5 didn’t have a reboot from internal or sd hooks in kodi iirc. You could try to flash to SD and see if it boots. The WP2 has a hook in uboot where you can push a button on the remote while booting to switch between SD and NAND.
