Help, please! How to boot this device into CoreELEC-long press power button, menu button or toothpick method? Thank you!
tooth pick / rest button for me (inside the 3.5mm jack)
note mine will not boot with the 4gb dtb even though it is supposed to be 4gb. it will only work with 2gb dtb.
others have reported same. a couple with the 4/32 (like mine) and another with the 4/128 version
