Hello, I have a strange issue with my X96 Max plus box. I tried to run both Coreelec 9.2.8 and 19.2 with the same issue. The issue happens when the CE is on SD card and also in emmc.
The issue:
When I start CE for the first time with reset button, everything works fine and initial configuration runs perfectly. But when I unplug the box from electricity then the next start-up ends up in a reboot cycle. The box keeps rebooting until its unplugged and plugged again. Then CE will start, but with no connection to wifi. I have to click restart from the menu in CE and then it loads up correctly.
Do you know, what can cause such an issue? Thanks for any help.
