X96 Max Plus Q2 suppot broken from CE19.5
I have a X96 Max Plus Q2 tvbox. CoreELEC 19.2 to 19.4 can work without issue. The DTB file is sm1_s905x3_4g_1gbit.dtb. From CE19.5, I got bad video output. The resolution is low (640X480), and the color is distorted. I have tried CE20, 21, and 22. All the same bad video output.
Could you devs fix this issue? Thanks.
Do a fresh install of the latest nightly, then provide logs:
Log from CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20251117-Generic.img.gz
Log from CoreELEC-Amlogic-ng.arm-19.4-Matrix-Generic.img.gz
