Greetings and thank you for the great Coreelec system, which I have been using for several years and is really perfect against Androind.
I have a question about the X96 Max+ Q2 4/32GB box. Box works great with Coreelec, but neither WIFI nor BT works under Coreelec 9.2.7, under Coreelec 19 Matrix_rc4 both WIFI and BT work. For some reason, I’m forced to stay on Kodi 18.9, so I want to ask if drivers from newer versions of Coreelec will ever be added to older versions of Coreelec 9.2.7? Or is there a way to port these drivers to Coreelec 9.2.7? Thank you for answer.
