Hello.
I have X96 Max 4/32Gb (with revision R) running the latest stable CE 9.2.1.
I have external HDD (with PSU) and noticed that it is working very slow, dd says it’s only 2 Mb/sec.
I have tried to optimize the disk, check it’s smart and checked every block. Everything is fine.
On Linux and Windows benchmarks show 34-35 Mb/sec (connected USB2.0), but when I connect the disk to CE - the speed is like it was before, nothing changes.
I have taken another disk (2.5" without PSU), checked it as well, reformatted, connected to CE, and when I try to copy something to it - it hangs.
I thought that the disk is feeling bad, but both disks looks fine on two different computers.
And they act very strange in CE.
Here is the dmesg output:
[26798.684666@2] usb 1-2: new high-speed USB device number 10 using xhci-hcd
[26798.825538@2] usb 1-2: New USB device found, idVendor=1058, idProduct=070a
[26798.825562@2] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[26798.825565@2] usb 1-2: Product: My Passport 070A
[26798.825568@2] usb 1-2: Manufacturer: Western Digital
[26798.825571@2] usb 1-2: SerialNumber: 575848314131303437313534
[26798.826436@2] usb-storage 1-2:1.0: USB Mass Storage device detected
[26798.826618@2] usb-storage 1-2:1.0: Quirks match for vid 1058 pid 070a: 200000
[26798.826666@2] scsi host0: usb-storage 1-2:1.0
[26799.838125@1] scsi 0:0:0:0: Direct-Access WD My Passport 070A 1032 PQ: 0 ANSI: 4
[26799.843066@1] scsi 0:0:0:1: Enclosure WD SES Device 1032 PQ: 0 ANSI: 4
[26799.885716@0] sd 0:0:0:0: Attached scsi generic sg0 type 0
[26799.886509@0] scsi 0:0:0:1: Attached scsi generic sg1 type 13
[26799.886806@2] sd 0:0:0:0: [sda] 623769600 512-byte logical blocks: (319 GB/297 GiB)
[26799.888389@0] sd 0:0:0:0: [sda] Write Protect is off
[26799.888400@0] sd 0:0:0:0: [sda] Mode Sense: 23 00 10 00
[26799.892265@1] sd 0:0:0:0: [sda] No Caching mode page found
[26799.892275@1] sd 0:0:0:0: [sda] Assuming drive cache: write back
[26799.943777@0] sda: sda1 < sda5 >
[26799.950964@2] sd 0:0:0:0: [sda] Attached SCSI disk
[26800.446868@3] ntfs: driver 2.1.32 [Flags: R/W MODULE].
[26800.448664@3] ntfs: (device sda5): parse_options(): Unrecognized mount option big_writes.
[26800.448674@3] ntfs: (device sda5): parse_options(): Option utf8 is no longer supported, using option nls=utf8. Please use option nls=utf8 in the future and make sure utf8 is compiled either as a module or into the kernel.
[26800.529559@0] fuse init (API version 7.26)
[26865.339570@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[26872.815070@0] DI: DI: tasklet schedule cost 12ms.
[26880.114598@0] DI: DI: tasklet schedule cost 12ms.
[26882.994410@0] DI: DI: tasklet schedule cost 12ms.
[26883.414406@0] DI: DI: tasklet schedule cost 12ms.
[26896.793607@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[26907.272992@0] DI: DI: tasklet schedule cost 12ms.
[26916.532500@0] DI: DI: tasklet schedule cost 12ms.
[26916.652474@0] DI: DI: tasklet schedule cost 12ms.
[26921.192222@0] DI: DI: tasklet schedule cost 12ms.
[26927.756166@2] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[26928.499939@1] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[26936.559466@3] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[26955.882578@2] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[26966.974080@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[26967.910014@0] DI: DI: tasklet schedule cost 12ms.
[26989.309118@0] DI: DI: tasklet schedule cost 12ms.
[26989.429136@0] DI: DI: tasklet schedule cost 12ms.
[26996.028872@0] DI: DI: tasklet schedule cost 12ms.
[26997.944829@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27017.748096@0] DI: DI: tasklet schedule cost 12ms.
[27024.087882@0] DI: DI: tasklet schedule cost 12ms.
[27028.776050@3] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27028.919760@2] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK
[27028.919772@2] sd 0:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 04 a6 d7 f0 00 00 f0 00
[27028.919777@2] blk_update_request: 35 callbacks suppressed
[27028.919780@2] blk_update_request: I/O error, dev sda, sector 78043120
[27028.919786@2] Buffer I/O error on dev sda5, logical block 9754878, lost async page write
[27028.919807@2] Buffer I/O error on dev sda5, logical block 9754879, lost async page write
[27028.919812@2] Buffer I/O error on dev sda5, logical block 9754880, lost async page write
[27028.919817@2] Buffer I/O error on dev sda5, logical block 9754881, lost async page write
[27028.919822@2] Buffer I/O error on dev sda5, logical block 9754882, lost async page write
[27028.919826@2] Buffer I/O error on dev sda5, logical block 9754883, lost async page write
[27028.919831@2] Buffer I/O error on dev sda5, logical block 9754884, lost async page write
[27028.919835@2] Buffer I/O error on dev sda5, logical block 9754885, lost async page write
[27028.919840@2] Buffer I/O error on dev sda5, logical block 9754886, lost async page write
[27028.919844@2] Buffer I/O error on dev sda5, logical block 9754887, lost async page write
[27029.527756@2] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27060.754778@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27061.426736@0] DI: DI: tasklet schedule cost 12ms.
[27066.306595@0] DI: DI: tasklet schedule cost 12ms.
[27066.426610@0] DI: DI: tasklet schedule cost 12ms.
[27066.766572@0] DI: DI: tasklet schedule cost 12ms.
[27081.606191@0] DI: DI: tasklet schedule cost 12ms.
[27082.026175@0] DI: DI: tasklet schedule cost 12ms.
[27084.446109@0] DI: DI: tasklet schedule cost 12ms.
[27087.286054@0] DI: DI: tasklet schedule cost 12ms.
[27091.786000@1] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27092.245914@0] DI: DI: tasklet schedule cost 12ms.
[27092.445943@2] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27104.385667@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27114.265404@0] DI: DI: tasklet schedule cost 12ms.
[27125.485176@0] DI: DI: tasklet schedule cost 12ms.
[27126.565195@0] DI: DI: tasklet schedule cost 12ms.
[27134.801063@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27153.400704@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27153.680908@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27158.304544@0] DI: DI: tasklet schedule cost 12ms.
[27161.484473@0] DI: DI: tasklet schedule cost 12ms.
[27164.064433@0] DI: DI: tasklet schedule cost 12ms.
[27168.064374@0] DI: DI: tasklet schedule cost 12ms.
[27175.364259@0] DI: DI: tasklet schedule cost 12ms.
[27180.808209@2] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27180.948830@0] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[27180.948843@0] sd 0:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 04 a7 10 30 00 00 f0 00
[27180.948848@0] blk_update_request: I/O error, dev sda, sector 78057520
[27180.948853@0] buffer_io_error: 20 callbacks suppressed
[27180.948856@0] Buffer I/O error on dev sda5, logical block 9756678, lost async page write
[27180.948875@0] Buffer I/O error on dev sda5, logical block 9756679, lost async page write
[27180.948880@0] Buffer I/O error on dev sda5, logical block 9756680, lost async page write
[27180.948884@0] Buffer I/O error on dev sda5, logical block 9756681, lost async page write
[27180.948889@0] Buffer I/O error on dev sda5, logical block 9756682, lost async page write
[27180.948894@0] Buffer I/O error on dev sda5, logical block 9756683, lost async page write
[27180.948898@0] Buffer I/O error on dev sda5, logical block 9756684, lost async page write
[27180.948902@0] Buffer I/O error on dev sda5, logical block 9756685, lost async page write
[27180.948906@0] Buffer I/O error on dev sda5, logical block 9756686, lost async page write
[27180.948911@0] Buffer I/O error on dev sda5, logical block 9756687, lost async page write
[27185.924091@0] DI: DI: tasklet schedule cost 12ms.
[27185.960135@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27186.624086@0] DI: DI: tasklet schedule cost 12ms.
[27186.924075@0] DI: DI: tasklet schedule cost 12ms.
[27188.344051@0] DI: DI: tasklet schedule cost 12ms.
[27201.063848@0] DI: DI: tasklet schedule cost 12ms.
[27216.815723@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27222.083580@0] DI: DI: tasklet schedule cost 12ms.
[27226.123553@0] DI: DI: tasklet schedule cost 12ms.
[27229.283529@2] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27256.199282@2] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27276.035030@2] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27287.227009@2] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27287.367541@2] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[27287.367553@2] sd 0:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 04 a7 11 20 00 00 f0 00
[27287.367558@2] blk_update_request: I/O error, dev sda, sector 78057760
[27287.367564@2] buffer_io_error: 20 callbacks suppressed
[27287.367566@2] Buffer I/O error on dev sda5, logical block 9756708, lost async page write
[27287.367585@2] Buffer I/O error on dev sda5, logical block 9756709, lost async page write
[27287.367590@2] Buffer I/O error on dev sda5, logical block 9756710, lost async page write
[27287.367595@2] Buffer I/O error on dev sda5, logical block 9756711, lost async page write
[27287.367599@2] Buffer I/O error on dev sda5, logical block 9756712, lost async page write
[27287.367603@2] Buffer I/O error on dev sda5, logical block 9756713, lost async page write
[27287.367608@2] Buffer I/O error on dev sda5, logical block 9756714, lost async page write
[27287.367612@2] Buffer I/O error on dev sda5, logical block 9756715, lost async page write
[27287.367616@2] Buffer I/O error on dev sda5, logical block 9756716, lost async page write
[27287.367621@2] Buffer I/O error on dev sda5, logical block 9756717, lost async page write
[27302.874824@1] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27322.802627@0] DI: DI: tasklet schedule cost 12ms.
[27333.806746@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27338.202518@0] DI: DI: tasklet schedule cost 12ms.
[27356.002428@0] DI: DI: tasklet schedule cost 12ms.
[27357.922386@0] DI: DI: tasklet schedule cost 12ms.
[27361.762367@0] DI: DI: tasklet schedule cost 12ms.
[27364.770429@3] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27365.450483@1] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27366.562340@1] DI: DI: tasklet schedule cost 12ms.
[27379.322384@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27384.742261@1] DI: DI: tasklet schedule cost 12ms.
[27409.838214@1] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27409.958210@3] usb 1-2: Device not responding to setup address.
[27410.166208@0] usb 1-2: Device not responding to setup address.
[27410.374147@3] usb 1-2: device not accepting address 10, error -71
[27410.494191@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27410.614166@3] usb 1-2: device descriptor read/64, error -71
[27422.782110@1] DI: DI: tasklet schedule cost 12ms.
[27426.542185@3] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27457.954831@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27458.830765@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27460.494096@1] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27481.690070@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27503.741980@0] DI: DI: tasklet schedule cost 12ms.
[27504.861973@0] DI: DI: tasklet schedule cost 12ms.
[27511.982024@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27514.050007@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27517.581978@0] DI: DI: tasklet schedule cost 12ms.
[27534.438073@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27534.558007@2] usb 1-2: Device not responding to setup address.
[27534.765977@1] usb 1-2: Device not responding to setup address.
[27534.973943@2] usb 1-2: device not accepting address 10, error -71
[27535.093971@0] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27535.213985@2] usb 1-2: device descriptor read/64, error -71
[27535.462537@2] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[27535.462549@2] sd 0:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 04 a7 7c f0 00 00 f0 00
[27535.462554@2] blk_update_request: I/O error, dev sda, sector 78085360
[27535.462558@2] buffer_io_error: 20 callbacks suppressed
[27535.462561@2] Buffer I/O error on dev sda5, logical block 9760158, lost async page write
[27535.462580@2] Buffer I/O error on dev sda5, logical block 9760159, lost async page write
[27535.462584@2] Buffer I/O error on dev sda5, logical block 9760160, lost async page write
[27535.462589@2] Buffer I/O error on dev sda5, logical block 9760161, lost async page write
[27535.462593@2] Buffer I/O error on dev sda5, logical block 9760162, lost async page write
[27535.462597@2] Buffer I/O error on dev sda5, logical block 9760163, lost async page write
[27535.462601@2] Buffer I/O error on dev sda5, logical block 9760164, lost async page write
[27535.462605@2] Buffer I/O error on dev sda5, logical block 9760165, lost async page write
[27535.462610@2] Buffer I/O error on dev sda5, logical block 9760166, lost async page write
[27535.462614@2] Buffer I/O error on dev sda5, logical block 9760167, lost async page write
[27535.590003@2] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27535.710006@0] usb 1-2: Device not responding to setup address.
[27535.918106@0] usb 1-2: Device not responding to setup address.
[27536.125956@2] usb 1-2: device not accepting address 10, error -71
[27536.246141@1] usb 1-2: reset high-speed USB device number 10 using xhci-hcd
[27536.365973@0] usb 1-2: device descriptor read/64, error -71
