X96 Max+ s905x3 problem with keyboard while using usb hub
Hi all
My setup:
  • X96 MAX+ box
  • 21.1.1-Omega_nightly_20250102
  • keyboard Logitech K400 Plus
  • usb hub Vention Neuer USB 3.2 Gen2 HUB 5 Ports Splitter 10 Gbit/s USB A Typ C HUB Multiport Adapter Laptop Erweiterung Desktop PC Zubehör - AliExpress 7
  • 4tb seagate drive 2.5"
    I was suing before 2TB external 2.5" HDD directly connected to usb 3.0 port and keyboard connected to 2.0 port.
    After buying 4tb drive there was not enough power coming to it over usb 3.0 port - HDD was starting/ stopping so i found old belkin 2.0 usb hub powered over small plug(not usb plug) from power outlet.
    All was fine but i though speed over wifi was slow/dropping from 20 mbps(max speed of old drive while transfering files from pc to box over wifi) to near 0 and then back so i was thinking hub is the problem as old hdd connected directly to usb 3.0 was giving stable transfer.
    Decided to buy na ew usb hub - got 3.2 powered over usb c port - using google charger - should be more than enough to give power to the hub.
    Problem is that when hub is connected to the box keyboard is not reacting, pressing keys gets laggy or not working at all for some time after some time it is working fine and after short while not working properly.
    Anything i could do or check except buying another hub?
    Files without usb hub connected, only Logitech usb dongle
    journalctl -l --no-pager | paste
    https://paste.coreelec.org/ShrunkHounding
    lsusb -vv | paste
    https://paste.coreelec.org/LarvaJoining
    dmesg | paste
    https://paste.coreelec.org/FamousMeager
Afret reboot, with usb hub connected, hdd not connected, “locked” keyboard
https://paste.coreelec.org/SergeantTabby
lsusb -vv | paste
can’t get device qualifier: Resource temporarily unavailable
can’t get debug descriptor: Resource temporarily unavailable
can’t get hub descriptor, LIBUSB_ERROR_TIMEOUT (Resource temporarily unavailable)
cannot read device status, Resource temporarily unavailable (11)
https://paste.coreelec.org/CohenYessir
dmesg | paste
https://paste.coreelec.org/MercerIvory
Cheers
Small update hub causes no problem while connected to usb 2.0 port.
