I just got a new 2G/16G X96 Mini, and wanted to boot to CoreELEC from MicroSD and/or USB.
- I downloaded the image CoreELEC-S905.arm-8.95.2.img.gz
- I burnt it with Etcher to USB stick
- I copied the file gxl_p281_2g.dtb from the device tree to the root folder and renamed it …dtb.img
When I try to reboot the device it is stuck on the very first screen showing the X96 symbol. I have tried 2 different USB sticks and a sd card, I have tried both the toothpick method and to reboot from within Android withTerminal Emulator. Nothing gets me beyond this first screen. It boots fine into Android without USB/sc card
Am missing something?
Thanks for your help
