Hi, Apologies if this has been dealt with alreadt. I’ve searched before asking.
I’ve got a X96 Mini with 2 gigs ram. I’m using gxl_p281_2g.dtb from CoreELEC 20.1-Nexus
Everything but my wifi works fine, it sees my wifi network, but when I connect with my wifi password it doesn’t actually connect. I’m using WPK2 b/g. Does anyone know what I can do to make it work ?
In the normal X96 mini interface wifi works perfectly with the same wifi key.
As per other posts. V19.5 works perfectly.There must be a bug introduced in Nexus 20.x
