Hi all,
This is probably a stupid question, but where is the .config folder to copy remote config files?!
I have found remote control files for my X96 Amlogic S905X box and remote from the repository, but can’t find the .config folder mentioned in the guides. Here is the listing I have in the Samba share - folders — ImgBB - If I access the root of the storage via Kodi I can see the Android system folders and have tried copying the remote.conf file to the etc folder there via Coreelec but I get an error, presumably a permissions error? I have also copied the remote.conf file to the root of the SD card, the remote.conf and rc_maps.cfg files to the \Configfiles folder and also the rc_maps.cfg to the \Configfiles\rc_keymaps folder, all without success.
How can I get to .config to copy the files there, or is there another step I’m missing to get the remote working?
Thanks!
