i try to wget x96max vfd.conf for repo, changed the name to vfd.conf and put it into .config folder
reboot the coreelec , won’t work
you need install the “OpenVFD addon” in kodi.
i already installed openvfd addon from repo in kodi . but it wont work
Make sure you wget the raw file, not the html version.
Try this one, vfd.conf (1.2 KB)
It works on my X96 Max+ 4/32
Thanks, on a 4/32 X96 max plus AI it worked the first time.
