ntamas
4 February 2022 14:33
1
Hi all!
I have an X96 mini with 2 gb of ram.
With the new version of Coreelec 19.4(matrix) is not working for me with the original dtb image- gxl_p281_2g
But with Coreelec 9(leila) works fine with the same nema dtb gxl_p281_2g.
I tried with gxl_p281_1g but is laggy video has low fps.
Some solution?
Garcea
4 February 2022 14:43
2
Did you follow all the steps here Wiki ?
ntamas
4 February 2022 14:49
3
Yes!
I renaimed every time, and just with matrix is not working with 2GB version
Garcea
4 February 2022 15:05
4
Did you try to boot from usb? Or a different booting solution: reboot to Libreelec, fake update or upgrade from 9.2.8 to 19.4?
bhf
4 February 2022 15:19
5
You have to update your bootloader at least up to Android 7.1.x in order to run CE Matrix.
ntamas
4 February 2022 17:36
6
Hoe? Can change the bootloader, the android is atxexperience android 10
I have one of these boxes, and it has S905W chipset which cannot run CE_ng/Matrix.
ntamas
4 February 2022 20:07
9
somebody have that problem addons with inputstream is laggy or lot off buffering, have (hbo go, amazon prime , netflix)???
Garcea
5 February 2022 16:22
10
https://forum.kodi.tv/showthread.php?tid=339798&pid=3084398#pid3084398
HBO Go works after this workaround, Netflix doesn’t. Try and see what happens!
And about Netflix: Netflix Add-on [input-stream]
ntamas
7 February 2022 19:31
12
Thanks, Fixded all platform
system
Closed
10 May 2022 03:27
14
