does anybody have experince with flashing coreelec image directly to emmc? I can boot from SDcard but I would like to replace complete android and use linux only. Thanks.
I want to flash a x96 mini with CoreELEC in the emmc and it says that gxl_281_2g isn’t supported. Is there a solution?
Original message:
Yo también estoy interesado en flashear un X96 mini con coreelec en la emmc y me dice que el archivo gxl_281_2g no es soportado ¿Alguna solución?
This is an English language forum, use it or use Google translate if you can’t.
Did you try the command for unsupported devices ceemmc -x
Good evening, I haven’t tried it, and sorry for not sending the post in English, I didn’t know it.
Where can I find more information on how to use the command on unsupported devices? Thanks.
Did you try the most obvious: using Search option for " ceemmc -x".
It should point you to this extensive explanation. At the bottom is the chapter of your interest
“Unsupported devices:”
Prueba con el de 1G.
