X98Q No arranca Coreelec
I have a problem with this tv box.
It’s a s905w2 with 2GB of ram and there’s no way to get coreelec to boot. all the steps are fine but there is no way.
any solution ???
Well in the end I managed to get CE to boot but from USB since it doesn’t work from SD.
The problem now comes from the fact that the tv box doesn’t turn off… you turn it off, it supposedly turns it off but it doesn’t. The light stays in Blue as on and it continues to emit a signal because my TV recognizes the hdmi
