Hi guys, I can’t get my white Xbox one bluetooth controller working… . Starting from scratch, I can see any Bluetooth Device listed twice from CE… Trying to pair with my controller (obviously set on ‘pair’ mode), I always get an Input/Output error.
Lurking on the web, I found one suggestion saying to connect via SSH to the system and then push a
echo 1 > /sys/module/bluetooth/parameters/disable_ertm
Tried it without success; after the command, each Device is shown once (and not twice as before), but I still get an I/O error Trying to pair the controller.
I know most probably this is not a CE issue, but maybe someone had my same problem and was able to troubleshoot it… So, any suggestion is welcome. (I’ll try to get some log in the meantime)
Sorry guys, I didn’t mean to make anyone hangry… And thanks to Poida and Adamg for the patience.
In the meantime I Tried to lurk the kodi log but what I found is not talking at all:
now working in kodi and retroarch with this line in autostart echo 1 > /sys/module/bluetooth/parameters/disable_ertm and this99-terios.rules (244 Bytes) autostart.sh (78 Bytes)
you have to connect at every start,it does not always pair itself
