30.10. In 2019, broadcasts in the Czech Republic were changed to dynamic PMT tables. TVH has since reported the following:
2019-11-01 08:56:42.709 mpegts: 706MHz in DVB-T2 - tuning on Panasonic MN88472 #0 : DVB-T #0
2019-11-01 08:56:42.709 subscription: 015E: “127.0.0.1 [ admin | Kodi Media Center ]” subscribing on channel “ČT 1 (T2)”, weight: 150, adapter: “Panasonic MN88472 #0 : DVB-T #0”, network: “DVB-T2”, mux: “706MHz”, provider: “CESKA TELEVIZE”, service: “CT 1 HD T2”, profile=“htsp”, hostname=“127.0.0.1”, username=“admin”, client=“Kodi Media Center”
2019-11-01 08:56:44.201 TS: DVB-T2/706MHz/CT 1 HD T2: HEVC @ #2110 Continuity counter error (total 1)
2019-11-01 08:56:44.201 TS: DVB-T2/706MHz/CT 1 HD T2: AC3 @ #2122 Continuity counter error (total 1)
2019-11-01 08:56:44.201 TS: DVB-T2/706MHz/CT 1 HD T2: TELETEXT @ #2130 Continuity counter error (total 1)
2019-11-01 08:56:44.201 TS: DVB-T2/706MHz/CT 1 HD T2: AAC @ #2120 Continuity counter error (total 1)
2019-11-01 08:56:44.201 TS: DVB-T2/706MHz/CT 1 HD T2: AAC @ #2121 Continuity counter error (total 1)
2019-11-01 08:56:44.201 TS: DVB-T2/706MHz/CT 1 HD T2: AAC @ #2123 Continuity counter error (total 1)
2019-11-01 08:56:44.240 tbl-base: pat: 706MHz in DVB-T2: invalid checksum (len 4098, errors 1)
2019-11-01 08:56:44.373 TS: DVB-T2/706MHz/CT 1 HD T2 Transport error indicator (total 1)
2019-11-01 08:56:44.711 TS: DVB-T2/706MHz/CT 1 HD T2: AC3 @ #2122: Invalid start code 70:68:d0
2019-11-01 08:56:54.319 TS: DVB-T2/706MHz/CT 1 HD T2 Transport error indicator (total 171)
2019-11-01 08:56:54.642 TS: DVB-T2/706MHz/CT 1 HD T2: TELETEXT @ #2130 Continuity counter error (total 11)
2019-11-01 08:56:54.743 tbl-base: pat: 706MHz in DVB-T2: invalid checksum (len 2157, errors 3)
2019-11-01 08:56:55.199 TS: DVB-T2/706MHz/CT 1 HD T2: AAC @ #2123 Continuity counter error (total 8)
2019-11-01 08:56:55.302 TS: DVB-T2/706MHz/CT 1 HD T2: DVBSUB @ #2150 Continuity counter error (total 1)
2019-11-01 08:56:56.062 TS: DVB-T2/706MHz/CT 1 HD T2: AAC @ #2121 Continuity counter error (total 11)
2019-11-01 08:56:56.351 TS: DVB-T2/706MHz/CT 1 HD T2: HEVC @ #2110: Invalid start code ff:ff:ff
2019-11-01 08:56:56.462 TS: DVB-T2/706MHz/CT 1 HD T2: AAC @ #2120 Continuity counter error (total 4)
2019-11-01 08:56:57.065 TS: DVB-T2/706MHz/CT 1 HD T2: HEVC @ #2110 Continuity counter error (total 10)
2019-11-01 08:56:57.261 TS: DVB-T2/706MHz/CT 1 HD T2: AC3 @ #2122: Invalid start code 10:ff:ff
2019-11-01 08:56:57.636 TS: DVB-T2/706MHz/CT 1 HD T2: AC3 @ #2122 Continuity counter error (total 8)
since then, only the sound can be played. Tuner works correctly with XBOX ONE! Can you advise anyone?
