Xiaomi Mi BOX Bluetooth remote help
I’ve purchased a cheap Xiaomi Mi BOX Bluetooth remote:-
However I’m having problems getting it to work. It connects fine via bluetooth but CoreELEC seems to think it’s a game controller:-
And when I try cat /proc/bus/input/devices it’s not listed.
I: Bus=0010 Vendor=1b8e Product=0cec Version=0001
N: Name="cec_input"
P: Phys=
S: Sysfs=/devices/virtual/input/input0
U: Uniq=
H: Handlers=kbd event0
B: PROP=0
B: EV=3
B: KEY=1 0 0 0 0 100000 0 0 0
I: Bus=0019 Vendor=0000 Product=0000 Version=0000
N: Name="meson-ir"
P: Phys=meson-ir/input0
S: Sysfs=/devices/platform/ff808040.meson-ir/rc/rc0/input4
U: Uniq=
H: Handlers=kbd event4
B: PROP=0
B: EV=100013
B: KEY=fff 0 0 4200 108fc32e 2376051 0 0 0 7 158000 4192 40004801 9e96c0 0 0 10000ffc
B: MSC=10
Anybody have any ideas how to get this remote working? Thanks.
Does anybody have any ideas why this remote is detected as a game controller and not a remote?
You’ll need a udev rule like this stored under /storage/.config/udev.rules.d:
The rule assigns the remote to the hid-generic driver instead of the default controller driver.
This is for my the bundled remote for my mibox 3, however, and you’ll need to adapt the ATTR{HID_ID} and the ID being echoed according to your actual device. You should be able to figure out yours by using udevadm monitor.
Thanks for the reply.
I’ve run udevadm monitor and when I connect the remote I get this response:-
UDEV [60999.434417] add /devices/platform/ff500000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/bluetooth/hci0/hci0:65 (bluetooth)
Which part of that is the ID?
I can also run bluetoothctl and it returns the following info for the remote:-
CoreELEC:~ # bluetoothctl
Agent registered
[CHG] Device B4:20:5B:A5:C2:5C RSSI: -84
[Xiaomi RC]# info
Device DC:E5:33:31:BB:40 (public)
        Alias: Xiaomi RC
        Class: 0x00000504
        Icon: input-gaming
        Paired: yes
        Bonded: yes
        Trusted: yes
        Blocked: no
        Connected: yes
        LegacyPairing: no
        ManufacturerData Key: 0x0000
        RSSI: -46
        TxPower: 0
But again I don’t know the ID.
