After today, when install zerotier from Entware, was not possible to start the service.
zerotier-one -d give the follow message: “-sh: zerotier-one: not found”
After goes to /storage/.opt/bin/ and change the file zerotier-one from a old version, everything works again…
Someone to give a help…
I assume file was not there? Then it can’t run
@truztruz : Sorry I can’t confirm it, many months ago I stopped using entware-zerotier replacing it with docker zyclonite/zerotier on all my CE devices even the oldest ones.
I use this install command:
docker run -d \
--name 9993-zerotier-one \
--device=/dev/net/tun \
--net=host \
--cap-add=NET_ADMIN \
--cap-add=SYS_ADMIN \
--cap-add=SYS_RAWIO \
-v /storage/.config/dockers/zerotier-one:/var/lib/zerotier-one \
--restart unless-stopped \
--privileged \
zyclonite/zerotier
# commands
# docker exec 9993-zerotier-one zerotier-cli status
# docker exec 9993-zerotier-one zerotier-cli join <your-zt-network-id>
I also recommend that you always install the docker portainer utility
Hello vpeter , yes the file is there, but i believe is some error in the version of that file.
The file was fixed, now everything works normally again.
Some Moderator can close the thread please.
Thanks you both for help.
system
Closed
16 July 2022 05:02
7
