Please try Nightly build. If still issue then upload full log again and ce-debug output
Iām sorry, even on nightly problem persist.
log: http://ix.io/2SHW
ce-debug: http://ix.io/2SHX
Try in .kodi/userdata/Database/MyVideos119.db
Donāt see something special in config. Only a lot of decoder errors. Will test you sample tomorrow.
And your link on how it looks on TV also doesnāt work.
OK, thank you very much. Iām afraid that something is wrong with TV/TV setup/HDMI input.
Iām sorry, Iām new here and donāt know all rules about posting. So I got message that three links in a post is too much, I panicked and deleted that link. Hereās the video playback on TV one more time.
https://drive.google.com/file/d/13qqAOI9X7OC1wWefs-8A8D081sjKQEbU/view?usp=sharing
Again, thank you for your help, much appreciate that.
And does it still play good with 9.2?
Surprisingly no, itās not. I made clean CE 9.2.6 install on my test SD card and itās the same problem like on CE19. Maybe test SD card isnāt ok.
I meet some strage problems:
- I use the addon āBing: Photos of the weekā as the screensaver. If the screensaver active when I am in CoreELEC settings, the banner picture of CoreELEC will be replace with the Bing logo after I exit the screensaver.
- After I installed some"Look and feel - image collections"addons, I canāt backup in the CoreELEC settings.
If I do that, Kodi or the skin will reload.(I am not sure it is the Kodi or the skin) And I check the ābackupā folder, the .tar file is only several MBs. It is not a full backup obviously.
After Kodi or the skin reloaded, if go to the CoreELEC settings and try to backup agian. It happens again.
And after that if I try to shutdown or reboot in the powermenu, the screen will be freeze and I need to unplug and plug the power adapter to reboot.
What exactly plug is causing this problem. I have the same and cannot locate the problem.
@fxj368, @tomasiek
Could you try latest nightly and check?
If still the same issue then try to switch to default skin and repeat backup procedure.
If still the same then please collect full log and crashlog on latest nightly.
It looks to me like a defect then. If it worked before and doesnāt anymore then something broke.
I also checked this demo file, all plays good for me.
You can try to replug cable in different TV port to check. Do it only with both powered off box and TV.
Also I hope you have a normal power supply on your box too.
Itās not something CE-19 related.
Hereās the demo file playbacked by my primary system SD card. Everything works fine, so I am gonna do nothing with it. Everything in this everyday setup is the same like in test setup, except the SD card.
https://drive.google.com/file/d/13uyP-5SCqsQuwolORFvzESj-JFnV-HkH/view?usp=sharing
My result: Itās card related
The latest nightly has solved the second problem. But the first problem still happen.
I donāt know the exactly addon. It seems files is too large to be backed up. But Iām glad the second problem wonāt happen in lastest nightly.
I think itās something addon related
Repeat actions to receive this issue and collect full logs. May be something will be in log or may be not.
Also check that you use latest 1.0.5 version
Image add ons that stopped my CoreELEC back ups were Animated Weather icons and Red Carpet Pings (actresses)
Log: http://ix.io/2SMB
I use 1.0.5 version, the first problem still happen.
Donāt know if backups are hindered by mounted drives, but ceemmc is. I have my pictures share mounted on my box for picture slideshow screensaver. Ceemmc counts all those terabytes of my NAS as data to try and cram onto my 8GB emmc
Yes, when u mount it to /storage it will copy it to eMMC. Kodi normal do mount it in /var/media
