For 1st issue I need full log, but not crash log.
Are you using petitboot?
No, I am not. I boot directly to CoreELEC, no dual boot. When I want to change system, I have to manually change SDcards. My petitboot version: 20201222.
So the switch is set to emmc right? Because I saw these corruption with petitboot before.
Yes, I double checked that, it’s on the right side, close to eMMC (SD cards) slots. And I do not see petitboot interface. Hardkernel logo and CoreELEC splash screen immediately.
did not know that, I’ll reconfigure my stuff then.
I think it should be right this time.
From logs I don’t see nothing related to this issue.
Some addon feature.
Hello!
I have OTA updated CE on the Beelink GT1 mini to 9.2.6 “Leia”, and up to copy the proper dtb file on the SD card. But as I see the dtb file in the newer Matrix version is much different from this one. So, my question is, if I leave the Leia 9.2.6 running for now, but when there would come another OTA update to some newer Matrix version, than I have to do the dtb change manually again?
Thanks!
You only need once to update your “generic” dtb.img to the new dtb. Matrix do update correctly by itself to the new dtb on upgrade.
Sorry, and for to avoid all misunderstanding: what you mean by “generic”? This one?: g12a_s905x2_4g_1gbit.dtb / Because as the GT1 mini has now it’s own dedicated dtb file. For Leia it’s: g12a_s905x2_beelink_gt1_mini_4g (and also has a _2g version) and it’s 68Kbytes, but for the Matrix there’s only one now: g12a_s905x2_beelink_gt1_mini and it’s only 34Kbytes. So they’re definitely not the same… So I’m still confused regarding, would need some more clear explanation, thank you…
(I know that _4g means that it’s for the 4GB Box version, but that’s not what causes the confusion).
On 9.2 you have 2g and 4g, yes. On Matrix only one for both
Yes I know this, but so in the light of all the above that has mentioned, it still apples what you stated?
So I can now copy the g12a_s905x2_beelink_gt1_mini_4g dtb file for 9.2.6 Leia, and when an OTA update comes with the Matrix sometime, it will automatically exchange the dtb for it’s proper one dedicated for the GT1 Mini?
Just one thing, there’s no plan to force an update from Leia to Matrix. If you want to enter the Matrix train you’ll have to update manually.
thank you, this was the solution for me.
Had been reporting the local error and everything coreelec settings related was refusing to load.
Apparently en-GB was an unrecognised locale… didn’t know the UK was so obscure
on a separate note, how do i move to nightlies for 19. The relkai.coreelec.org/release.json route does not work for me on 19. does it mean manually downloading them and dropping them in update folder?
That takes a lot of consideration to decide… BTW is there any further improvement/fixes/etc. in the Matrix version of the GT1 mini .dtb file, compared to the Leia version?
So I’m back with almost the same problem.
Installed is 19.0 Matrix nightly 20210315, but I also have the problem with the versions before and with 9.2.6.
Ugoos Am6 -> AVR (Yamaha RX V4) -> TV (Q80T) (HDMI)
1080p resolution ground with 60hz and 50hz are displayed. 30hz and 24hz I get a black screen.
3840x2160 is displayed with 60,50,30,25 hz. 24hz flickers the picture. 23.98 is stable.
4096x2160 is stable at 23.98hz.
I switched the resolutions one after the other and saved the logs.
http://ix.io/2SWY
http://ix.io/2SWZ
New scenario:
Am6 -> TV -> AVR (Earc)
http://ix.io/2SX1
http://ix.io/2SX2
All resolutions are displayed correctly with all Hz frequencies. The only problem is that the sound is no longer output correctly via the Earc interface for some series / films.
With older versions of CoreElec I did not have the problems with the AVR.
Your whitelist is wrong
You have only 2160p30, 1080p50 and 720p50
videoscreen.whitelist: 0384002160030.00000pstd,0192001080050.00000pstd,0128000720050.00000pstd
You should try with empty whitelist or exclude only smpte and lowest resolutions
hy my problem:
ERROR: You need to specify a valid device for the Amlogic-ce project
Valid devices for project: Amlogic-ce
- Amlogic-ng
*********** FAILED COMMAND ***********
. config/options "${1}"
File "<string>", line 1
import os; print(f'{os.cpu_count() * 1.5:.2f}')
SyntaxError: invalid syntax
You forgot to post what you entered! You only need to run make, so it’s user error.
