I think it’s fixed now and nightly 20240726 should work properly now.
New nightly installed and nothing has changed,
This is the log you have requested:
https://paste.coreelec.org/PartlyShrunk
Thanks @Portisch
Ok. Will wait tomorrow for the new nightly.
Many thanks Maestro Portisch.
Many thanks @Portisch all working good on lg c6 4k oled passive 3D + MINIX_U22 XJMax.
Just two caveat, My Gs king x sometimes crashes (will try& give logs later) but I use the Minix mostly so no major & can gui delay after stopping 3D be fixable?
Many thanks, brilliant work as always genius💪 .
@Portisch Thank you very much for making this happen. My kids love watching 3D movies and now thanks to you I can put them on my Unraid server. You don’t even care or believe in 3D but you still took your time to do this. I will now grow my collection because I don’t like having to use bluray disks. Please let me know how I can buy you a beer or two. Everyone should that uses 3D because without you this would not of been possible.
New nightly is up.
Thank you @Portisch 0726-nightly working beautifully like a charm here.
Just my GSKX crashes on some 3Ds
I try click adverts here to help but can we somewhow donate something for all your effort.
Many thanks.
New nightly CE-21 Amlogic-ne 20240727 on SoC SC2 (S905X4) should also now support 3D. If you get strange colours with MVC media please start/stop one time any H264 media file. Looks like a register must be cleared by the decoder first.
SoC like T7, S4 and S5 aren’t supported yet as they use the new hdmitx21 driver.
Maestro Portisch you are a genius. For the first time in my system everything 3D and not 3D work as it should. I have no more words left to thank you and the CE Team for this great accomplishement. Warmest congrats.
:smiley: :smiley: :smiley:
Please all, disable adblock and click as many ads each time you visit here. Is as of now our only way of showing gratitude :pray:
Been following this thread with interest, and am super excited to see 3D added as a feature. I have the latest nightly build, but when I try to play a 3D MVC file it just goes to a blue screen. Is there a toggle in the settings that I need to switch? Thanks!
I have tested 3D with today’s nightly “CoreELEC-Amlogic-ne.aarch64-21.1-Omega_nightly_20240727” in the homatics r 4k plus, and it works perfectly.
One more step ahead.
Thanks again.
When you play a MVC file right after boot the colours are correct? Here I need to play one h264 media before it works correct.
Yes, the colors are correct on 3 MVC i have tested.
I have repeated the test also from a cold start and the colors are correct always. on MVC files.
Thank you for being a maestro of testing.
CE-22, Amlogic-ne and Amlogic-no should support also 3D with new nightly 20240730.
Except: MVC frame packaging SoC with hdmitx21 driver. These are T7, S4 and S5 SoC. Like as example Amlogic-no and G12B, Odroid N2+ does work fine.
The other modes (F)SBS and (F)TAB are working fine on all SoC.
I am not sure if this hdmitx21 issue will be solved one day or not.
Maybe a new (4k) 3D media format do arrive earlier…
Thanks @Portisch. What box would be an example of a S5 SoC? Don’t see it on the dev status page.
Great that 3D will be supported on AmLogic-NE & -NO. But, not until there’s a dovi.ko to also be able to have dual-layer, player-led DV right for S922X or another SoC right? Or, am I confused on this? Very possible :blush:.
S5 is S928X, it’s missing in the wiki.
Afaik dovi.ko is available for -NE, but not for -NO
