Good morning all
I was currently on Matrix 19.2 and updated to Matrix 19.4.
By switching to this version, HDR10+ films no longer play on my non-HDR TV. They are black and colorless.
So I tried different versions and only Matrix 19.4 Rc1 works with my HDR10+ movies to my SDR TV.
Do you have an idea of the problem.
My Box is an F2 S905X2
Regards Laurent
Try the latest nightly.
I run an S905X2 on a non HDR TV and HDR to SDR is as good as it gets.
It’s a known problem that HDR10+ to SDR and HLG to SDR is currently broken.
I just haven’t had time yet to look into it further.
OK thanks for your answer.
Hopefully this issue will be resolved in the future.
So i stay on Matrix 19.4 Rc1
It’s on my list of things to try and fix. I just need to get enough free time to take a closer look at it.
For something that is broken it certainly worked as well as it has ever done with my tests of HDR10+ material.
Reading an Hdr 10 film on an HDR television is ok, but an Hdr 10 film on a non-Hdr television does not work.
It may be ok for you but for those who don’t have HD TV, no
I don’t have an HDR TV either.
I just downloaded the latest nightly 20220413 and I still have my black screen problem with Hdr movies on my Sdr tv even with the Hdr to Sdr tone map feature enabled
