Did you copy this files or you copy content of this file?
If content, than check via Notepad++ for correct EOL Conversion, must be Unix (Edit->EOL Conversion)
Also you have to be sure that correct dtb.img device-tree used.
@boot2k3
I’ve copied the file, not only its content.
Now I opend the file with vi and saw that the encoding is wrong (DOS/CRLF). So the pre made config file was the issue here. The keymap file (m8s) is ok. Only the rc_maps.cfg is faulty.
I have a T95N, it’s a Mini M8S II clone (even has that on a small label on the box) and that config file works just fine, because I made it myself with the remote that came with the box.
Maybe something corrupted the file between the time I posted it and when it ended up in that dropbox folder. Glad you got it working.
Hey @canna would you mind sharing those files? I do have the exactly same issue and I’m not able to solve it, I’ve tried many configurations and none of them is working. I’ve also done the EOL Conversion and that didn’t help either.
You have to be sure that correct dtb.img device-tree used from img.gz or tar file and not from different internet source.
If still doesn’t work after 1st step than upload files somewhere to check what is wrong
I have tried many of them I have Mini M8S II and from what I’ve read I should use gxl_p212_2g but none of them will boot. The only img that’ll boot is from LibreElec that came with it as it was stated that for S905X I don’t need to change the dtb file.
I hope you renamed it to dtb.img?
For CE you need to use only device tree from CE tar.gz and not from LE. And of course you need to rename correct dtb file to dtb.img
