That’s not a bug, it’s a skin issue. The Estuary skin is patched to add CE shortcuts.
Also you can get to the CE Setup through the addons.
Thanks for the reply.
The Eminence 2 MOD developer has suggested how his skin could be patched to add a CE shortcut, but unfortunately his solution does not work.
I thought that the file that was used to used to patch the Estuary skin might provide a clue, but I can’t find it.
Any chance of letting me know which file was used?
Cheers
For the benefit of Eminence 2 MOD skin users, my query has now been resolved and after a future update, CoreELEC should appear in the Eminence Kodi Main Menu.
No one seem have this issue but when I play a movie on a Samba share it take some “long” seconds before start. On 8.95.5 version of CoreElec the same file/same samba share start instant without any delay.
It’s a know issue ?
9.0.1 logs
2019-04-19 15:46:16.927 T:4093292464 NOTICE: VideoPlayer::OpenFile: /storage/.mkv
2019-04-19 15:46:16.928 T:3711955824 NOTICE: Creating InputStream
2019-04-19 15:46:16.949 T:3711955824 NOTICE: Creating Demuxer
2019-04-19 15:46:16.993 T:3711955824 NOTICE: Opening stream: 0 source: 256
2019-04-19 15:46:16.993 T:3711955824 NOTICE: CVideoPlayerVideo::OpenStream - Creating codec: 27
2019-04-19 15:46:16.999 T:3711955824 NOTICE: Creating video thread
2019-04-19 15:46:16.999 T:3674207088 NOTICE: running thread: video_thread
2019-04-19 15:46:17.000 T:3711955824 NOTICE: Opening stream: 1 source: 256
2019-04-19 15:46:17.000 T:3711955824 NOTICE: Finding audio codec for: 86019
2019-04-19 15:46:17.000 T:3711955824 NOTICE: Creating audio thread
2019-04-19 15:46:17.000 T:3665814384 NOTICE: running thread: CVideoPlayerAudio::Process()
2019-04-19 15:46:17.000 T:3711955824 NOTICE: Opening stream: 2 source: 256
2019-04-19 15:46:17.011 T:3665814384 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, pass-through)
2019-04-19 15:46:17.011 T:3665814384 ERROR: CAEStreamInfo::GetDuration - invalid stream type
2019-04-19 15:46:17.029 T:3674207088 ERROR: Previous line repeats 1 times.
2019-04-19 15:46:17.029 T:3674207088 NOTICE: CAMLCodec::OpenDecoder - using V4L2 pts format: 64Bit
2019-04-19 15:46:17.623 T:4093292464 NOTICE: Whitelist search for: width: 1280, height: 720, fps: 23.976, 3D: false
2019-04-19 15:46:17.625 T:4093292464 NOTICE: Display resolution ADJUST : 3840x2160 @ 23.98 - Full Screen (37) (weight: 0.000)
2019-04-19 15:46:18.046 T:4093292464 NOTICE: VideoPlayer: OnLostDisplay received
2019-04-19 15:46:19.460 T:3665814384 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
2019-04-19 15:46:22.917 T:3830981488 ERROR: Previous line repeats 1 times.
2019-04-19 15:46:23.497 T:3665814384 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
2019-04-19 15:46:34.917 T:3830981488 ERROR: Previous line repeats 6 times.
2019-04-19 15:46:36.171 T:3665814384 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
2019-04-19 15:46:37.653 T:4093292464 NOTICE: VideoPlayer: OnResetDisplay received
2019-04-19 15:46:41.033 T:4093292464 NOTICE: CVideoPlayer::CloseFile()
8.95.5 logs
15:52:15.575 T:4088381360 NOTICE: VideoPlayer::OpenFile: /storage/.mkv
15:52:15.576 T:3970945904 NOTICE: Creating InputStream
15:52:15.599 T:3970945904 NOTICE: Creating Demuxer
15:52:15.654 T:3970945904 NOTICE: Opening stream: 0 source: 256
15:52:15.656 T:3970945904 NOTICE: Display resolution ADJUST : 1920x1080 @ 23.98 - Full Screen (32) (weight: 0.000)
15:52:15.747 T:4088381360 NOTICE: VideoPlayer: OnLostDisplay received
15:52:15.747 T:4088381360 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
15:52:15.747 T:4088381360 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
15:52:16.079 T:3970945904 NOTICE: CVideoPlayerVideo::OpenStream - Creating codec: 27
15:52:16.094 T:3970945904 NOTICE: Creating video thread
15:52:16.094 T:3979338608 NOTICE: running thread: video_thread
15:52:16.095 T:3970945904 NOTICE: Opening stream: 1 source: 256
15:52:16.095 T:3970945904 NOTICE: Finding audio codec for: 86019
15:52:16.097 T:3970945904 NOTICE: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder ac3
15:52:16.097 T:3970945904 NOTICE: Creating audio thread
15:52:16.097 T:3736068976 NOTICE: running thread: CVideoPlayerAudio::Process()
15:52:16.097 T:3970945904 NOTICE: Opening stream: 2 source: 256
15:52:16.106 T:4088381360 NOTICE: VideoPlayer: OnResetDisplay received
15:52:16.160 T:3736068976 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
15:52:16.210 T:3979338608 NOTICE: CAMLCodec::OpenDecoder - using V4L2 pts format: 64Bit
15:52:16.512 T:4088381360 NOTICE: Display resolution ADJUST : 1920x1080 @ 23.98 - Full Screen (32) (weight: 0.000)
15:52:20.208 T:4088381360 NOTICE: CVideoPlayer::CloseFile()
EDIT :
Someone have the file “CoreELEC-Amlogic.arm-8.99.2-LePotato.img.gz” for test if this version have the same issue or not please ?
Hey, can someone please tell me if gxl_p212_2g.dtb is the correct device tree for beelink mini mx III II ?
Thank you,
Never mind I see the answer. thanks for all you do
Perusing your logs, I notice that the big time delay is a difference between the two: Resolution switching.
In 8.95 your screen was at 1080P 23.976 and switched (not) to 1080P 23.876 which took about zero time.
In 9.0.1 your device made a switch from an unknown, but apparently different resolution, to 2160P 23.976 which required many seconds through your output chain (whether it was just the output device or a receiver and the output device).
If there is really an issue, you need to get logs from either a more similar configuration or the same video, preferably both.
Hey, when using Cyberduck software to SSH a tar update with Libreleec the username and password was “root” and “libreelec”. Is that still the same with CoreELEC?
Thank you
@frem no… the root password is coreelec and fyi upgrading from LE to CE is not possible, you need a fresh install unless you want a brick.
Thanks, i have a fresh SD card with coreELEC and the correct tree. I’ll remove the Libreelec card, then reboot with the toothpick method as before. Is there a noticeable difference between Libreelec and coreELEC?
Is there anything other than the above that I need to do?
No, just look for noticeable differences
The switch from 1080p to 2160p is almost instant but it’s not what take time. (=0.5s)
Picture come almost instant is just wait without playing the movie at all.
These lines take 17s !
And someone can send me an older version can’t download anymore on GitHub.
Anything older than 9.0 is no longer available as these was unstable alpha/beta versions which we are no longer doing given the amount of problems they caused.
Closing due to 9.0.2 release, further discussion here .
