Post whole debug file. Not just one line.
pvr.iptvarchive is already at version 3.5.7.2!
IPTV Simple (not Archive) showed as 3.5.7.2 and it also canāt be installed with the same error.
You are using wrong (old) repository from CE 9.0. Now with CE 9.0.1 different repository is used.
Try to refresh CoreELEC repository (Context menu āCheck for updatesā).
What you get by command
cat /usr/share/kodi/addons/repository.coreelec/addon.xml
cat /storage/.kodi/addons/repository.coreelec/addon.xml
Same version, but different URL
Manual deletion of /storage/.kodi/addons/repository.coreelec solved the problem! Strange why āCheck for updatesā didnāt work (tried many times either with reboot and no). Thank you @vpeter!
Did you made /storage/.kodi/addons/repository.coreelec manually? Or it was made by CE itself or did you install any repository.coreelec zip?
My installation has a long update history
But no, i definitely didnāt create it manually and didnāt make manual repo install, as i can recallā¦
Same Problem here after update. Canāt enable pvr simple addon. I got another issue, the coreelec custom definitions dissapear.
This only happens if you downgraded CE and used some custom repository.corelec in
Yes, Iāve downgraded CE once, but without doing something manually with the repo. Anyway, thanks for the clarification, mine problem is solved now!
Thank you, @anon88919003. Missed that.
I think it might have someting to do with the layout of the majority of new models of this type of remote; i believe that hard assigment of the bottom right key is actually pause now, which is what it does by default during live play. It would be great to be able to adjust the āhamburgerā key again. If not, i could live without or i will have to resort to my own keymap in storage again
Problem solved following the same process as @vevs
- improved subtitle rendering
Does this refer to the subtitle stuttering issue or something else?
If the second command above returs output, should that file, or the direcotry ārepository.coreelecā be deleted to ensure proper autoupdating?
I have two Tanix 3 mini devices here and I updated both from the same downloaded file.
One of them apparently removed the file while the other did not.
What is the best course of action?
As @Ray wrote just remove folder /storage/.kodi/addons/repository.coreelec.
rm -rf /storage/.kodi/addons/repository.coreelec
Thanks for the confirmation.
@Atreyu Quote wrxtasy (he updated the code): No time tonight - ask if he has custom Keymaps enabled. They will need to be reset to defaultā¦
Thank you, @Ray.
First thing i did was remove any customizations.
The issue is, that the new ācontext menuā button is assigned to play/pause now, which is a un-recognized code on this Xiaomi model (in a context where nothing is playing).
What i did for now, is create some custom keymap files in \storage as described by wrxtasy:
https://forum.kodi.tv/showthread.php?tid=317011&pid=2645790#pid2645790
Then, i used the previous evmap as below, all fine now
contents:
KEY_POWER = KEY_MUTE
KEY_COMPOSE = KEY_STOPCD
KEY_HOME = KEY_HOME
KEY_BACK = KEY_EXIT
@fs_candido: No, this folder should be removed because there is no reason to exists. And problem will arrive again on next update if still there.
