Thank you very much for your answer but I wanted the beautiful splash screen with what coreelec 9.2.0 starts itself. I don’t know where to find it.
splash-1080.zip (917.7 KB)
Just unzip this file and follow previous instructions.
Thank you very much ukmark62.
I bought one for me to have some fun, I hope it does not have the same boards.
why, oh why, are they still making boxes without gigabit ethernet…
50 c save…
Still looking for some input with the stuttering issue I posted above. There was some changes made since 9.0.3 that causes this. If you need more info/logs I can see what I can pull.
Has anyone gotten SFTP to work and scan your library / files
Bug of PVR is solved in last last versions from v4.5.2 - Speed up EPG loading. PLease update for 9.2 and also for 9.0.3 (if is possible) ThX. changelog of pvr iptv
Addons were updated a couple of days ago.
Since i upgraded my Odroid N2 to version 9.2.0 the librespot addon doesn’t work for me anymore.
I can activate it and see it being active in the logs, but it cannot be found from the Spotify apps.
Of course the devices are in the same LAN and it worked just fine, before I upgraded Coreelec.
Here are my Coreelec logs, if you need more information just tell me:
http://ix.io/20IT
I’ve found nothing remarkable just the normal logs like this :
2019-11-03 19:06:26.404 T:3708257152 NOTICE: Librespot: playback stopped
2019-11-03 19:06:26.404 T:3708257152 NOTICE: Librespot: start librespot
2019-11-03 19:06:58.931 T:3708257152 NOTICE: Librespot: abort requested
2019-11-03 19:06:58.931 T:3708257152 NOTICE: Librespot: aborting player
2019-11-03 19:06:58.931 T:3132089216 NOTICE: Librespot: control pipe []
2019-11-03 19:06:58.932 T:3132089216 NOTICE: Librespot: control pipe stopped
2019-11-03 19:06:58.933 T:3708257152 NOTICE: Librespot: service stopped
and sometimes this here:
Nov 02 20:30:30 CoreELEC kernel: "librespot" (16388) uses deprecated CP15 Barrier instruction at 0xab38f0dc
Nov 02 20:30:30 CoreELEC kernel: "librespot" (16388) uses deprecated CP15 Barrier instruction at 0xab38f0e8
Nov 02 20:30:30 CoreELEC kernel: "librespot" (16388) uses deprecated CP15 Barrier instruction at 0xab38f0f0
Probably related to this discussion here:
https://discourse.coreelec.org/t/s905x2-librespot-doesnt-work/7556?u=steasenburger
I think I am getting the same resolution switching issues treboR2Robert was discussing the previous 9.0.3 thread. i.e. getting black screens going from playing content back to menu
Anyone know what the fix or trouble shooting process is?
Hi. I’m thinking about getting one of those s905x3 boxes with 11.11 promotions.
Are any of them fully working? Or, will any be supported in a near future?
Thanks for your great effort!
I’ve enabled subtitles in the settings but they are still disabled when I try to play some movie. If I enable them and the Set as default for all media, they are still not enabled when I start a new movie.
How can I debug this one? I’m using an Odroid N2.
This is Kodi related. Try to replicate the issue on Windows/Linux/Android.
I think X96 Max+ is maybe good for you. it has s905x3, and has a Gigabit NIC, I bought one on taobao today.
When you have it, could you tell me the progress of CoreELEC in it?
Maybe for Black Friday or Christmas I’ll buy one. Android in this kind of boxes is a little crappy, I think, and I’m very happy with CoreELEC in a S912 box, so I’d like to change to a new box, but with a stable/running version of CoreELEC.
Thanks!
I used to use an S912 and went to an S905X2 I find the picture quality of the S905X2 is not as good as the S912. The colours arn’t as bright and often skin tones seem a little orange / sepia. It is a little like the early versions on S905 were a little cartoon like. I have no doubt it will improve as it did with the S905. I need to do some testing to see if its the upscaling that is the problem also i need to test in android to see if the picture quality is better there.
I have ordered an “X96 Max +” too they are GB£22 US$28 with 4GB Ram 1GB Ethernet and 5G Wifi I can use it for something even if CE Does Not Work.
I can should received the box on tomorrow (Nov 12), and I will test coreelec nightly builds.
The only SM1 (S905*3) device supported at this time is the Khadas VIM3L, none of these other devices will work with our images, the image we created for VIM3L will also not work on other devices.
Please move S905X3 talk to an appropriate thread.
