temp0
14 January 2020 12:03
163
@kostaman Can this be relevant? Different kernel but as my wifi is Broadcom, it seems related. Is mentioned fix backported to v3.x kernel too?
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=843387
Thank you!
EDIT:
Btw. I found another possible fix from Nvidia mentioned here:
https://devtalk.nvidia.com/default/topic/1036350
Direct link to code change here:
https://devtalk.nvidia.com/default/topic/1047138/jetson-tx1/wifi-disconnect-problem-on-jetpack-3-3/post/5314700/#5314700
Is it relevant?
Thank you.
EDIT2:
Found the disconnection reason (code=6):
6 - Class 2 frame received from nonauthenticated STA ==> Client attempted to transfer data before it was authenticated.
https://www.aboutcher.co.uk/2012/07/linux-wifi-deauthenticated-reason-codes/
temp0
15 January 2020 19:19
164
@kostaman @system Any news, hints?
Thank you.
Buenas noches,he instalado la version 905,y cada vez que arranco el tvbox sale un mensaje de que tengo que esperar 300 segundos a que arranca,y es cada vez,alguien sabe como quitar esa espera?muchas gracias.
Vasco
15 January 2020 19:33
166
This is an English forum so please use English. Your using the wrong dtb. You have to use the dtbâs provided with the image.
migrate from libreelec on vim1. install CE on internal storage, work great! thx!
Tate20
20 January 2020 19:13
168
Good morning, I have a couple of problems and I donât know why. The first is that when the bluetooch headphones are connected, the speed of Wi-Fi download drops alarmingly. I have proven that when you pause what you are seeing by not transferring the sound through the headphones, the speed increases again and remains constant. The second problem is that the lan cable network does not work. Any solution to these problems? Thank you
Thatâs most likely a hardware issue. Phones can have the same issue too. Try using 5GHz if you have it.
Tate20
20 January 2020 19:48
170
I do not have 5 hz. And the problem of ethernet cable connection?
You could be using the wrong DTB.
Tate20
20 January 2020 20:29
172
My tvbox is the beelink gt1. Whatâs the right DTB?
Hi Tate20. Whatâs the first four digits of the serial number S/N, found underneath of the box. Thanks
Vasco
20 January 2020 20:52
175
Itâs the gt1 standard or the gt1 ultimate?
Perhaps the gxm_q201_3g_1gbit one.
Vasco
20 January 2020 20:55
177
Gt1 standard is gxm_q201_2g_1gbit.dtb because it has only 2 gb ram. If itâs the ultimate it has 3gb (or 2 for those with for ram).
The first be the Standard. So It reads S912⌠for first four digits of the S/N found underneath of the unit, correct?
Tate20
21 January 2020 08:11
181
As the gxm_q201_2g_1gbit file is downloaded, I canât find a way to download it. SOLVED
