yes i have V81 and MT 7668
Since 20200706 it’s possible to choose libCEC version for testing.
Default is libCEC 4.0.4. By touch a new file /storage/.config/libcec-4.0.5.conf after a reboot libCEC 4.0.5 will be used. When removing the touched file 4.0.4 will be used again.
Has the DVD menu issue not been sorted out yet? 9.2.2 Discussion
No and I guess it will never as the error to fix is too time consuming.
I got a error when I try to run Emby, is it a coreclec bug or a network error?
It worked fine when I use 9.2.1
Update:OK, I think I need a VPN.
Here is the log
2020-07-15 20:23:08.882 T:3769365376 NOTICE: EMBY.hooks.webservice -> —>[ webservice/57578 ]
2020-07-15 20:23:08.885 T:3897660288 NOTICE: EMBY.patch -> —>[ patch ]
2020-07-15 20:23:08.886 T:3897660288 NOTICE: EMBY.patch -> --[ check updates/DEFAULT ]
2020-07-15 20:23:08.923 T:3897660288 NOTICE: EMBY.patch -> ERROR:: HTTPSConnectionPool(host=‘[raw.githubusercontent.com](http://raw.githubusercontent.com/)’, port=443): Max retries exceeded with url: /MediaBrowser/plugin.video.emby.objects/master/objects.json (Caused by NewConnectionError(’<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0xe019b790>: Failed to establish a new connection: [Errno 111] Connection refused’,))
2020-07-15 20:23:08.937 T:3897660288 NOTICE: EMBY.patch -> ERROR:: HTTPSConnectionPool(host=‘[raw.githubusercontent.com](http://raw.githubusercontent.com/)’, port=443): Max retries exceeded with url: /MediaBrowser/plugin.video.emby.objects/master/objects.json (Caused by NewConnectionError(’<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0xe019bbf0>: Failed to establish a new connection: [Errno 111] Connection refused’,))
Traceback (most recent call last):
File “/storage/.kodi/addons/plugin.video.emby/resources/lib/patch.py”, line 145, in check_update
versions = versions or self.get_objects_versions()
File “/storage/.kodi/addons/plugin.video.emby/resources/lib/patch.py”, line 120, in get_objects_versions
return requests.get(OBJ, verify=False).json()
File “/storage/.kodi/addons/plugin.video.emby/libraries/requests/api.py”, line 67, in get
return request(‘get’, url, params=params, **kwargs)
File “/storage/.kodi/addons/plugin.video.emby/libraries/requests/api.py”, line 53, in request
return session.request(method=method, url=url, **kwargs)
File “/storage/.kodi/addons/plugin.video.emby/libraries/requests/sessions.py”, line 468, in request
resp = self.send(prep, **send_kwargs)
File “/storage/.kodi/addons/plugin.video.emby/libraries/requests/sessions.py”, line 576, in send
r = adapter.send(request, **kwargs)
File “/storage/.kodi/addons/plugin.video.emby/libraries/requests/adapters.py”, line 437, in send
raise ConnectionError(e, request=request)
ConnectionError: HTTPSConnectionPool(host=‘[raw.githubusercontent.com](http://raw.githubusercontent.com/)’, port=443): Max retries exceeded with url: /MediaBrowser/plugin.video.emby.objects/master/objects.json (Caused by NewConnectionError(’<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0xe019bbf0>: Failed to establish a new connection: [Errno 111] Connection refused’,))
2020-07-15 20:23:09.019 T:3897660288 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<–
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type ‘exceptions.ImportError’>
Error Contents: cannot import name Movies
File “/storage/.kodi/addons/plugin.video.emby/service.py”, line 39, in
import entrypoint
File “/storage/.kodi/addons/plugin.video.emby/resources/lib/entrypoint/ **init** .py”, line 24, in
from service import Service
File “/storage/.kodi/addons/plugin.video.emby/resources/lib/entrypoint/service.py”, line 31, in
import library
File “/storage/.kodi/addons/plugin.video.emby/resources/lib/library.py”, line 16, in
from objects import Movies, TVShows, MusicVideos, Music
ImportError: cannot import name Movies
–>End of Python script error report<–
I’m running a Ugoos AM6 Plus. CoreELEC solved my audio drop-out problems but I find I get regular video freezes and it is impossible to resume from the point of freezing. Logs required?
Hi, i also own Ugoos AM6 Plus and i have the same problem. Video in format avi (format MPEG-4, codec XVID) freeze quite frequently. The only way to bring tv box back to life is to unplug the power.
Moreover all video format play mute quite frequently. I have to select a audio track manually and so the audio works. Thanks!
This is a known issue and somewhere related to Amlogic decoder hardware/software.
The hardware decoder just freeze randomly when playback get stopped.
If the AVI file is inside an MKV container, does this resolve the issue?
For me, it happens in MKV’s. Last night, I tried in Android instead of CoreELEC and the same thing happened which confirms what Portisch said.
.avi is already a container format containing video & audio.
.avi container can be demuxed with AviDemux and muxed into a .mkv container with the same program. Process is very fast as no transcoding is taking place, just file coppy…
That’s not what I was getting at.
I sometimes find odd playback behaviour with AVI files but if I then run them through mkvtoolnix to produce an MKV (wrapper if this term is preferred) and it does the trick, hence my suggestion.
Hi, I’m going to ask a very stupid question. Why does the Corelec team not collect firmware for Raspberry?
The PI uses a different hardware platform that is not AMLogic based.
I may not understand a lot, but the repository has “Projects/RPI”?
And Allwiner H3.
That is because we have forked from LE, and still pull changes from them to keep packages and other things up to date.
On launching CoreELEC last night, I got the Kodi Leia v18.8 update message. How do I update Kodi within CE, or do I have to wait until CE v9.2.4 is released?
You will have to wait. And we will need to look into how to remove this in future versions, because we’re not 100% in sync with the Kodi release cycle. Although Kodi 18.8 is supposed to be the last Leia release, so I’m not sure we really need to remove this check.
According to the list of updates in this release, the first is supposed to be quite serious so, is it likely you will release an updated version of CE with v18.8 or will you ride it out until Matrix v19.0 is eventually available?
